50cc Bogs - New Carb, timing good, new plug new cdi and new ignition
Old Sep 5, 2017 | 12:48 PM
Swensy77's Avatar
Default 50cc Bogs - New Carb, timing good, new plug new cdi and new ignition
Hey all...
I have a 50cc that I picked up for my son. I got it running and seemed to respond well. Put it in the frame and hooked everything up and started it. Under a load it will bog down and not accelerate and if I push throttle to fast it will bog down and die. I have put a carb from another one that is running well and did the same. Purchased a new carb and intake, same issue. For the life of me I can figure out why it bogs down this way. I also put in a new NKG plug, new working CDI and new coil with a new exhaust, nothing changes........ ANY HELP PLEASE
Old Sep 5, 2017 | 01:25 PM
Swensy77's Avatar
also compression was around 120
Old Sep 5, 2017 | 03:39 PM
LT80's Avatar
LT80 Expert
2 stroke or 4?
Name of quad?
Old Sep 5, 2017 | 04:07 PM
Swensy77's Avatar
It is a 4 stroke, no clue on brand, Chinese
Old Sep 6, 2017 | 04:08 PM
Swensy77's Avatar
Does anyone have any ideas?
Old Sep 6, 2017 | 04:45 PM
LT80's Avatar
LT80 Expert
I'm not a 4 stroke guy. If I had to guess, maybe valve lash adjustment?
Try installing another wire from frame to motor. Sometimes the motor doesn't ground.
Old Sep 6, 2017 | 05:09 PM
Swensy77's Avatar
yea good point ill check the grounds. And valve lash was just done...
Old Sep 7, 2017 | 08:45 AM
LT80's Avatar
LT80 Expert
I'm betting on the ground. Happened to me before so I always put a extra ground on.
Old Sep 7, 2017 | 08:57 AM
Swensy77's Avatar
Still didnt help lol I feel as if I have tried everything except rebuild the darn thing....
Old Sep 7, 2017 | 09:14 AM
Swensy77's Avatar
I took the chain off to see if the "resistance" would be an issue and that didnt help, I was going to look at the clutch but someone told me that that wouldnt help.... how much are the little 2stokes? lol
