1999 arctic cat 250 starter relay and neutral relay clicks when I push start
Old Nov 23, 2017 | 03:11 PM
Busterposey875's Avatar
Default 1999 arctic cat 250 starter relay and neutral relay clicks when I push start
Hello everyone I’m having a problem with my arctic cat 250 1999 so when I turn the key to the on position and press the start button all I hear is 2 clicks one from starter relay and another one from neutral relayand does not start or attempt to start
Old Nov 23, 2017 | 03:39 PM
hydrex's Avatar
Try another battery, check connection at starter. Then if no change, I might suspect the ignition switch itself. Otherwise, does it start and run ok with pull start?
Old Nov 23, 2017 | 04:01 PM
I have tried another battery and does the same thing the connection is good I have not tried the pull start I don’t use that at all
Old Nov 24, 2017 | 12:45 PM
hydrex's Avatar
Check voltage at starter when you turn the key. If it's 12volts plus, could just be the starter has died. So, if it has pull start, you still should be able to use, until fixed. I had an AC 400 that I could pull start easily when battery died.
Old Nov 24, 2017 | 01:04 PM
the starter is completely fine I just hear clicking when I push the start button
Old Nov 24, 2017 | 03:53 PM
Getting voltage to the starter cable? If not then usually a solenoid problem. If you're getting voltage,check connections on the battery,solenoid and starter cables for corrosion that could prevent a starter from working properly. You can always jump 12 volts directly to the starter to see if really works or not. If it doesn't,starters aren't that expensive.https://www.ebay.com/itm/Starter-FIT...tT4TZZ&vxp=mtr
mikieveee
Jul 22, 2016 02:40 PM
trx430ex
Apr 7, 2016 01:04 PM
Rattlerock
Mar 6, 2013 08:28 PM
Mr.Giggles
Jan 21, 2009 09:19 PM
katt68
Sep 11, 2007 08:16 PM
