No spark Chinese quad.
Old Jan 16, 2018 | 03:42 AM
Yamawho's Avatar
Default No spark Chinese quad.
Hi everyone, I am new here. Seems like google always directs me here when I have an atv connection, so finally made an account.
I just purchased a small Chinese quad. Not too sure of the size, maybe 80cc.
i was told it needed a simple carb rebuild.
I cleaned out the carb, check compression and checked spark and had no spark.
I am not sure if the CDI is bad or something else.
I disconnected the blk/wht wire from CDI, made no difference.
Wher can I go from here? just order a new CDI and coil?
The ignition harness also has a few wires disconnected.
The actual key ignition switch has 4 wires.
BLK
BLK/WHT
RED
GRN
The quad however has 7 wires near where the key goes, so I have no clue which ones go into the actual ignition switch. The colors the quad has are,
BLK/WHT
BRN
BLK
GRN
GRN
WHT
BLU
Any one have a clue as to which cable goes where?
Thank you.
Old Jan 23, 2018 | 10:17 PM
Yamawho's Avatar
Figured it out.
posting in case anyone else comes across this.
there was a safety button or switch near the rear grab bar that was cutting spark off.
hot wired it and fired right up.
Old Feb 15, 2018 | 05:39 PM
Firefighter George Gendron's Avatar
I have a nst 250 will not start the cdi is bad put a new on turned on key hit starter and cdiwent into melt down need the wiring harness connector it is a 2007 NST 250
Just My Luck!!!
1) Engine problems..
13
Jan 29, 2017 02:34 AM
fasctcarsca1
17
Nov 3, 2009 10:51 AM
ThomNY
Oct 24, 2008 08:45 PM
hartattack14
Sep 11, 2008 09:23 AM
rsekrecre1
Aug 29, 2008 11:01 AM
