Need help. No crank.
Old Mar 14, 2018 | 07:41 PM
neegzoo4's Avatar
Default Need help. No crank.
So, I just bought this 125cc TaoTao atv and when I try to start nothing happen. Battery fully charged. When i try to jump the starter relay the starter cranks but doesn't start. So, does anybody here know how to take out or how to bypass the remote starter or alarm? I'm assuming that, that is what keeping my atv from starting. Thanks.
Old Mar 17, 2018 | 10:05 AM
Zrock's Avatar
Super Quad Patrol
I would check your brake switch first as a brake has to be depressed for it to start.
Old Mar 26, 2018 | 09:49 AM
Jonathan Voss's Avatar
Im having the same issue, i disabled my brake switch to make sure that it was not the culprit. If you just follow the leads on the brake switch and just jump the 2 wires it will just bypass the brake safety switch all together, but your brake light will always be on.
This did not fix my no start issues, but if it helps you.
If you get this figured out please let us know i am having a no start issue also and cant figure it out.
Old Mar 26, 2018 | 10:32 AM
Zrock's Avatar
Super Quad Patrol
Depending on style of switch it may need to be jumperd, or left open
ScoobyDFW
Mar 16, 2007 03:09 PM
Uptmor250r
Oct 19, 2006 09:46 PM
Bigo05
Jul 11, 2005 04:23 PM
superevil
Jun 6, 2005 11:03 AM
blobby
Apr 7, 2000 01:03 PM
