Pantera 4x4 500 idel problem
Old Sep 15, 2019 | 09:12 AM
ranger 53's Avatar
Default Pantera 4x4 500 idel problem
My pantera 4x4 500cc when it's cold will idel fine but when it warms up it wants to rev at to high an idel to switch gears at all. I had the carb cleaned and set but it still does the same thing. Any suggestions would be helpful. Also looking for any manuals for it as well.
Old Sep 16, 2019 | 01:34 AM
Idle speed adjusting screw should be set so it will go into gear when hot. It is a compromise as bikes always rev higher on idle when hot. If it won't then idle when cold, so be it. If your carb's settings have been messed with, a little richer on the idle mixture screw may help the cold idle situation.
Old Mar 14, 2020 | 06:17 PM
ranger 53's Avatar
had to purchase a new Carb as Jets on the old one were totally flatend right out, totally destyroyed, and couldn't find replacements.
Pat B.
Jul 10, 2007 01:42 AM
ltdaddyo
May 11, 2006 11:30 PM
OKKeith
Utility ATVs
Mar 17, 2005 11:15 AM
quadracer31
Nov 3, 2002 10:00 AM
Boise
Aug 13, 2001 03:43 PM
