Starter problem
Old Jul 1, 2021 | 06:35 PM
Concealpro's Avatar
Default Starter problem
Recently purchased Kandi 125cc go kart. Starter only turns once or twice. Brand new battery and starter as well. If I pull the spark plug it spins fine.
Old Jul 2, 2021 | 02:34 AM
Check the leads from battery to solenoid, to starter, are clean and tight, make sure the new battery is fully charged. Check earths on battery, frame and engine too.
Old Jul 2, 2021 | 05:36 AM
Concealpro's Avatar
All wiring is good. It started fine over the weekend when I was trying to get the carb cleaned. Just didn't run. I turned it over probably 100 times it seems. It progressively got worse. I thought the starter may have just overheated, so I replaced it and the battery with no change. I've tried hooking power directly to the starter to bypass leads
Old Jul 2, 2021 | 10:39 AM
Concealpro's Avatar
Got it going. The sleeve in the carb was backwards, so wide open on start, the other carb had a stuck float flooding it as well before. Once I hooked a jump box to it, it had no choice but to turn over then revved up. Starts and runs fine now. My electrical issue in the other post was a bad ignition switch.
Rickybobby1118
Dec 1, 2013 01:23 PM
The original Firehawk
Apr 21, 2009 01:17 PM
randallp504
Dec 4, 2007 02:21 PM
targs
Apr 23, 2007 09:04 PM
cwdancer
Apr 7, 2004 12:14 AM
