Can’t keep Gio 110 running
Old Feb 19, 2022 | 03:16 PM
Scb1712's Avatar
Default Can’t keep Gio 110 running
Okay - my son has a Gio 110 quad that was running fine, but blew out the clutch mid summer. I finally got around to replacing the clutch as it took forever to find the right one.
After putting everything g back together I can’t get the quad to start without spray starter and can’t keep it idling. When I get it started I can rev it up and it seems to be running okay, but dies out when I try to come back to idle. I didn’t touch the fuel system at all when doing the clutch repair so not sure why I can’t get it to start and run without spray or keep it idling.
We live in Canada and the quad ran fine in the cold last winter too so don’t think that’s the issue. Any ideas??
Old Feb 20, 2022 | 03:14 AM
Clean the carb out. A lay up allows water to settle out and, if you removed the tank, the shake up can disturb dirt, which then floats through into the carb. Remove float bowl, remove jets, blow both them and the holes they came from out with compressed air, clean float bowl, re-assemble and try it. Do not alter needles or settings.
Beercan_22
1) Engine problems..
Aug 13, 2010 10:35 AM
BPRINCE
Feb 12, 2009 08:19 AM
shoemaro
ATC 3-Wheelers
Sep 28, 2008 04:28 AM
flknshane
Jul 28, 2006 07:24 PM
