50cc chinese something that wont start
Old Aug 21, 2022 | 12:51 PM
leesimpson1975's Avatar
Default 50cc chinese something that wont start
ok guys
i got a 50 cc kids quad for 150 Canadian dollars it ran with low compression when i got it, ran for about 5 mins then quit. since then i have done the following and it wont start now....need some help.
  • new starter
  • new oil and full gasket replacement
  • new battery
  • new wiring harness including stator
  • After compression test ( 60 PSI) - serviced the top end completely, everything looks good now (140 ish PSI) timing spot on.
  • stripped down the carb and noticed the crappy little choke lever was pooched but that wont stop the engine from firing if fuel is getting in ....I don't think? ( new cark is on the way though
So I'm now scratching my head now, I sprayed a load of quick start in the carb but nothing, what I did notice was that was coming out of the exhaust manifold, that's telling me the fuel is getting in but not firing...
right now i have the motor in the frame
and firing it up direct from a battery set up, i had the full harness on and everything connected correctly yesterday and the spark wasn't great when i tested the coil connections ( ill probably upgrade the plug when i get it running)
what am i missing? please help i need to get this thing running before my lady has a conniption !
MartinBH
Jul 19, 2022 02:08 AM
MartinBH
Jul 14, 2022 11:19 AM
Bigbloo
1) Engine problems..
Feb 5, 2022 02:42 AM
slidey
May 2, 2013 08:59 AM
james08
Oct 9, 2009 08:35 AM
