2) Chassis problems.. If your quad runs but you have other problems.. post in here.
taoTao 150
Old Jan 12, 2015 | 09:29 PM
NIL8er's Avatar
Default taoTao 150
Do these have bearings or bushings in swing arm , and what is normal play for these bikes. Thanks
Old Jan 13, 2015 | 09:48 AM
Swiftyyy's Avatar
Bushings, but they're really bad and the screw tends to be undersized, not even filling the bushing completely.
You shouldn't have any sideways movement in any of the joints, if you do it's advised that you do the same as I did and get some custom bushings made otherwise the frame will start to suffer and things will get damaged.
Old Jan 13, 2015 | 02:27 PM
Bernhard's Avatar
Bernhard Schmidt
Default Bernhard
Those tao Tao quad are a lot of work make sure you keep all bolts tight they are usually made of soft metal with improper maintenance these quads will fall apart just some advice I used to have one
hugemoth
Jul 20, 2020 03:28 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Randy Marsh
3) General Discussions..
21
Nov 10, 2015 01:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
