2) Chassis problems.. If your quad runs but you have other problems.. post in here.
125cc taotao charge issue
Old Feb 17, 2015 | 08:43 AM
Mike Napier's Avatar
Default 125cc taotao charge issue
new atv will charge batt at 14.ish volts with the lites off,if i apply the brake handle or turn the lites on the volts drops down to 12.2 ish and slowly drops,reving engine will not raise charging volts up.if i turn lites back off then the volts climb back up and hit a decent 14 some volts.
\any idea?
Old Feb 19, 2015 | 04:04 AM
Held off a bit as I'm not certain but I don't think anything is wrong. The engine is made for a scooter with one headlamp and the alternator may not be able to keep up with two headlamps.
Old Feb 19, 2015 | 05:27 AM
this model is the 3 speed forward 1 speed reverse semi auto
i already unhooked the big headlite and big tail lite
Old Feb 25, 2015 | 09:25 AM
Zrock's Avatar
Super Quad Patrol
Dunno about that if a manufacturer made one where the lights killed the battery then they would not sell to many units once the word got out. I would start checking the charging system and voltage regulator. Could also swap out the bulbs for some cheap ebay LED's
Old Feb 26, 2015 | 08:31 PM
whygostockcom's Avatar
Banned
Battery could be the issue. Doesn't sound like stator, but most likely the regulator if anything. Also unplug the remote control assembly. It can only casue problems and shorten battery life. That is if you are no longer using it.
hugemoth
Jul 20, 2020 03:28 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
cody500ho
14
Aug 14, 2015 05:03 PM
chris7420
Jul 30, 2015 02:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
