2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Help with 86 230 saft drive quadrunner
Old Aug 2, 2017 | 08:39 PM
Anthoney's Avatar
Default Help with 86 230 saft drive sazuki quadrunner
I just baught this quad it has hi low reverse and 2wd shft drive tanks under seat. The right side if rear axel hub hub and shaft teath are gone what other axel shafts are interchangeable?
Old Aug 3, 2017 | 09:43 AM
Zrock's Avatar
Super Quad Patrol
you will have to do some searching but when we had ours im pretty sure a older suz vehicle interchanged to that machine.
Old Aug 3, 2017 | 06:30 PM
Anthoney's Avatar
Ya iv been looking havent found anything to helpfull yet thanks for the info heads me in some direction anyway
Old Aug 4, 2017 | 03:31 PM
Anthoney's Avatar
I believe its a lt f230
Old Aug 5, 2017 | 02:00 AM
Parts book shows hubs as still available from Suzuki, but axle isn't. When we need an expensive or unavailable axle, a machine shop will either build up the splines with weld and re-machine or make a complete new axle, recent Timberwoolf axle, circa £800 from Yamaha dealers, machine shop price for a new one circa £260. Your local Quad dealership may know if there is such a machine shop in your locality.
Old Aug 5, 2017 | 07:00 PM
Anthoney's Avatar
I will look into this thank you for the info ivgot the hub off itvhas some spline left i might be able to fix it via weld with new used hub
