2) Chassis problems.. If your quad runs but you have other problems.. post in here.
High idle carb issue
Old May 8, 2018 | 11:53 AM
stanghater's Avatar
Default High idle carb issue
My Kazuma 150 has a weird carb issue. Its running great, pulls strong, no break up or anything. when I stop and let it idle, it idles so high, high enough that the quad is trying to move. Sometimes it will idle really high for about a minute then finally go back to regular idle rpm. sometimes it wont slow down and I have to turn it off. The carb is stock and it has a k&n style cone filter on it instead of the airbox. I am not a carb expert at all. can anyone point me in the right direction?
Old May 9, 2018 | 03:20 AM
Most obvious thing is the carb slide or butterfly sticking slightly open, or the cable sticking. If it is a CD carb, the dashpot piston may be sticking. Lots of other possibilities, but check them first.
sand dunner
Jun 17, 2022 09:49 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
cbaumy
Oct 18, 2010 08:57 AM
gfireboy22
Sep 28, 2007 02:01 PM
Hightower
Jan 23, 2003 05:58 PM
