110cc atv starts but won’t move
If you can't shove the bike by hand, the brakes are stuck. If you can, it may be anything in the transmission, but if it has a variator, the rubber belt will probably have broken. Other common problems are rear chain off the sprocket, or centrifugal clutch worn out. The bike usually moves with a worn clutch though, just not very fast.
