2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Need replacement shocks for LNA full size electric ATV!
Old Mar 23, 2023 | 01:39 PM
Sparkkky's Avatar
Default Need replacement shocks for LNA full size electric ATV!
Hello got new LNA 5000W electric ATV and I weigh about 175lbs and cannot get the suspension to move jumping on any corner.
Handicapped so I would prefer a soft ride but not too soft. Does anybody have a aftermarket brand for replacement shocks and is there really a difference between front and rear or mainly just the correct length?
Cheap ATV don’t want to spend a lot on shocks.
Old Mar 24, 2023 | 03:19 AM
Shocks are a total minefield, as extended length, free length, top mounting type and bottom mounting type, all need to be the same, unless you make special mountings, but the spring needs to be softer. Damping too may not suit your application. If the springs are removable, you may be able to find softer springs of the same dia and free length.
Old Mar 25, 2023 | 08:51 PM
Sparkkky's Avatar
Found some shocks that match the specs.
Anybody heard of Caiman Shocks sold by American CV? Uses same size as a couple of 400 Hondas.
Snipe
Utility ATVs
May 27, 2013 08:18 PM
ScoobyDFW
May 12, 2004 10:30 PM
rmx251
Apr 2, 2000 10:26 AM
REX
19
Sep 4, 1999 10:45 PM
