Need help with semi-automatic
Old Jul 15, 2011 | 02:38 PM
cyclebender's Avatar
Default Need help with semi-automatic
Have a Chinese twin cylinder 250 cc 4 stroke that is supposed to have a semi-automatic transmission. Pulled from a wrecked ATV with no identification on the ATV as to the manufacture. Searching the net, I found that the engine looks exactly like a Honda Rebel motorcycle engine. It has five forward gears and a clutch. Problem is I can’t get the motor to act like a “semi-automatic” With the motor running, the bike jumps when you shift from neutral to first, not the way I expected from a semi-auto trans. engaging the clutch doesn’t do anything, so I assume there is something wrong inside. Anybody have any experience or ideas before I start pulling the motor apart, since I don’t know what I’m looking for.
Old Jul 27, 2011 | 02:28 PM
Jaster94's Avatar
send some pics of the engine and transmission. we'll be able to give you some direction once we see what we're dealing with. both sides of the quad if you don't mind. thanks. yeah, better toss in a frontal shot also. look on the front of the quad at the pushbar area and see if it has a metal ID tag. if not, look under the left frame rail and look for the 17 digit VIN. we can run the numbers and maybe that'll tell us or give us a hint. does the engine/transmission/jug-cylinder area have any markings on it? thanks. let us know.
Old Jul 27, 2011 | 03:06 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Sounds like the engine that came in the Jetmoto 250 Utility quad I gave to my father in law.. its not a semi auto.. uses a clutch.. First thing Id check is that the clutch is adjusted correctly..next pull the clutch side cover and take a look..
Old Jul 27, 2011 | 03:55 PM
Default Clutch problem
Your right, pulled the clutch cover. This is a straigh manual clutch. Works fine since I re-adjusted the cable. Thank for your help.
Old Jul 27, 2011 | 05:12 PM
KTM Patrol
Former Chinese POW!
Your welcome
Racing Josh
Sep 17, 2010 04:14 PM
mustangman
Aug 6, 2006 10:29 PM
ATSAaron
3) General Discussions..
Jan 16, 2005 03:20 PM
extremerider2811
Dec 22, 2003 12:47 PM
Hondapride
Jun 15, 2001 05:36 PM
