tao tao 135cc
Old Jul 22, 2011 | 08:47 PM
TaoTao135cc's Avatar
Default tao tao 135cc
Have 135cc semi-auot 3 speed honda clone motor and the timing is off quite a bit..well I know how to remove the large metal circle to reveal the timing gear and chain BUT i need to take the chain off so I can adjust the gear and put the chain back on...My problem is the chain feels awfully tight and Iam sure I took out the tensior bolt..So I need to get to were the timing chain is in the bottom of the motor.... How do I get to it? It looks like if I take the clutch cover off it wouldnt get me to it and I had the stator cover off so I know its not there..Do I need to take the head off to get to it? Or is it behind the clutch cover? Is there even a manual for these?
Old Jul 23, 2011 | 07:00 AM
ok its a 125cc motor not a 135cc and no one has torn into one of these motors? hard to believe for as crappy as they are!
Old Jul 23, 2011 | 08:33 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the Forum TaoTao135cc!
You will need to take off the top of the engine(valve cover) and then remove the cam retainers so you can tilt the cam sideways to remove the chain from the sprocket.. loosening the cam chain adjuster doesnt allow for enough play.
Id go to Honda and get a manual for a 110 or 125cc 4 stroke engine.. Or ask Toa Tao if they have one..
LORO66
1) Engine problems..
8
Nov 29, 2014 09:25 AM
bernhardschmidt
Jun 21, 2014 12:32 PM
bernhardschmidt
May 22, 2014 08:47 AM
bernhardschmidt
May 14, 2014 08:37 AM
