Chinese Quad- body replacement/swap
Old Jul 26, 2018 | 01:55 PM
ian325is's Avatar
Default Chinese Quad- body replacement/swap
So after a long time searching the internet, I figured out what I have, but parts aren't available, which really isn't a surprise
What I have is a KPX commando 100 (I think made by QJ)
When I got it one of the front fenders was broken, and since I recently got it running Id like to try to make it look decent. Im pretty sure the majority of the Chinese quads are the same, so would anyone happen to know of another quad that I might be able to get a body for and put on? If I need to weld some tabs on that's fine, I just have no idea what might be close to compatible.
The engine is a minarelli 90cc (Yamaha clone) if that makes a difference?
Attaching a picture, Any info would be greatly appreciated. Thanks!!
Old Jul 27, 2018 | 02:14 AM
That humped tank shape and hole for the column that requires removing the handlebars to get it off, was used by many Chinese makers, so you should be able to get the front plastic for it, problem is knowing which makers. I have repaired a bike with a forward /reverse geared four stroke engine, which seems to have the same plastics, can't remember the maker though.
908240sx
Apr 30, 2017 04:36 PM
sofast
ATC 3-Wheelers
Jul 27, 2013 03:25 PM
streetbansheeking
Jan 27, 2013 10:10 PM
ThomNY
Oct 24, 2008 08:45 PM
GB
Jan 24, 2003 12:08 AM
