WARRIOR HUB QUESTION.
Old May 14, 2003 | 06:33 PM
Jonsride's Avatar
Default WARRIOR HUB QUESTION.
Just got a set of used rear spacers for my 2001 Warrior. My question is how do I take out the existing wheel studs. Are they a pressed in fit ?and is there a way to take them out without ruining them. Or are they a screwed in fit?. Thanks to the help.
Old May 14, 2003 | 06:35 PM
MojaveRider250's Avatar
i heard its a pain it the *** thats why people get the EZ fit ones but i dont know what u have to do. Just becareful u dont bend your axle!
Old May 14, 2003 | 07:58 PM
FISHER1648's Avatar
They are pressed in from the factory. Take the hub off the axle and use a socket to support the hub when tapping them out. It doesnt take too much.....
Sounds like you already have the non EZ-fit style. The EZ-fit screw right on the existing studs for easy install/removal. If it's not too late try them. Either way, wider helps !
Old May 14, 2003 | 08:11 PM
Fendercover's Avatar
Use a brass hammer when you knock the studs out or you'll mash the threads. They are easy to get out with the proper hammer and should only take a few smacks.
Old May 14, 2003 | 08:15 PM
Psycho's Avatar
I agree with Fender. Another option is use a phillips screwdriver and place it in the center of the lug and tap it with hammer(to keep off of threads).[img]i/expressions/face-icon-small-cool.gif[/img]
bigred20653
Oct 2, 2015 10:05 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Bigtwin700
Sep 9, 2015 09:32 AM
