Warrior question....
Old May 15, 2003 | 12:51 PM
RaptorFlash's Avatar
Default Warrior question....
I`m gonna go look at a few warriors tonight or tomorrow and got a question or 2. Anything I should look for? What years are the same(i.e. 96-03 are the same(looks, etc.))
Thanx Guys
Old May 15, 2003 | 03:25 PM
SpinCycle's Avatar
no real mechanical changes in the last 5yrs, but I thought that someone said they had changed the carb in about 99-00. Just look at the bottom of it for a good idea of condition. Check around the carb for leaks. The frame is pretty tuff, check the swing arm bushings and axle bearings. Do some measurements with a piece of string from the left front spindle to the right rear center of the axle and compare from side to side. This will tell you if it's straight. Good luck.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
