V-Force engine squeak!
Old May 15, 2003 | 08:03 PM
sportyroxx's Avatar
Default V-Force engine squeak!
My V- forces engines keeps making a high pitch squeaking noise. It only happens when its idle. It stops whenever i blip the throttle or get moving again it will stop. It doesnt always happen when its idle buy sometimes. I was just wondering if it is something i should worry about. Anyone with any info please help i appreciate it in advance.
Old May 16, 2003 | 08:52 AM
NovaKaw650's Avatar
It's the drive belt rubbing against the primary clutch when idling. Does it happen in neutral? I bet not. It's usually a sign that the belt is a little tight. It shouldn't be a problem. If on warranty you could get the dealer to check it.
Old May 16, 2003 | 05:59 PM
sportyroxx's Avatar
Yes it only happens when i am in drive, thank you for the info. It got me a little scared there for a while.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
