Head Gasket 88-92 LT250R
Old May 15, 2003 | 08:34 PM
dfox's Avatar
Default Head Gasket 88-92 LT250R
I'm re doing my top end and have an aftermarket gasket set. There is not a mark on the head gasket (Typically EX) to indicate the installation position. I am quite sure the smaller holes are towards the exhaust port however, not sure of the exact position. There is one section (on the gasket) between the head studs that has the water jackets blocked(no holes). My guess is that that section must go under the radiator port on the head ?
Any Ideas ?
1989 LT250R
Other Qauds
2003 Z400
1986 Honda 250R
Old May 15, 2003 | 09:45 PM
kevlt250r's Avatar
When I did the top end on mine I had a aftermarket headgasket. I was told by the my friend which is a good mechanic. He said to always use the factory suzuki gasket on the topend. They are alot better. You can tell a difference in them.
Old May 18, 2003 | 09:49 PM
Ronnnnn's Avatar
Did you figure out the correct placement for your non suzuki head gasket?
Old May 19, 2003 | 12:43 PM
dfox's Avatar
No not yet. I plan to call the vendor today. Will post if they are able to help.
Old May 19, 2003 | 06:01 PM
Ronnnnn's Avatar
I pm'd you.
tysonbully
Sep 28, 2015 02:30 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
