Lt 80 throttle stuck wide open
Old May 15, 2003 | 11:02 PM
450Rutmaker's Avatar
Default Lt 80 throttle stuck wide open
I need help I just got done taking the two rollers out of my sons 80. I went for a little spin and the throttle stuck. I shut it off wiggled the cable and it all looks fine so I started it up and off it went . What is the deal DID I DO SOMETHING WRONG WITH THE CLUTCH MOD or is it something else..
Thanks alot
Old May 16, 2003 | 10:21 AM
LT80's Avatar
LT80 Expert
You did nothing wrong.
Throttle sticking is just that.
This sometimes is caused be the cable being bad in general,or at the point where it comes out of the thumb throttle,it seems to get bent at this point.
lube the cable and lube the slide in the carb.
Make sure the cable dont bend on it's route to the carb.
Old May 18, 2003 | 09:41 AM
ok the throttle cable isnt kinked or anything it moves freely back in forth but it moves really freely like it isn't connected inside the carb is this possable and if that is my prob. would it be easier and safer for my son if I took it to a dealer?
Old May 18, 2003 | 11:49 AM
bsb1964's Avatar
Tough question 450rutmaker. I know one thing for sure, I highly reccomend teaching your kid to be familiar with the kill switch. Even if you get it fixed, they absolutely have to know where the kill switch is and always be ready to hit it. You never know.
Old May 18, 2003 | 01:21 PM
LT80's Avatar
LT80 Expert
For safety sake,,yes,, I would take it to a person that knows more!
You can check one more thing:: It sounds like the carb cable needs to be adjusted. this is done on the top of the carb (the hollow screw that the cable goes through w/lock nut) IF the cable is too loose,the cable can come out of the proper position and become lodged on the top of the hollow screw,thus the throttle sticks,or seems like it.
Old May 18, 2003 | 01:35 PM
now where the cable goes in the top of the carb is loose it seems you can pull it up and it moves about a 1/4 in. so do you just screw in back down or what
Old May 18, 2003 | 01:48 PM
LT80's Avatar
LT80 Expert
You unscrew (raise) the adjustment screw in the top of the carb.Adjust it till your thumb throttle has little to no play in it.
I think we found the problem [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 20, 2003 | 10:14 PM
LT80's Avatar
LT80 Expert
That fix it?
Old May 20, 2003 | 11:29 PM
I dont know yet the screw that you turn outward to tighten the cable was boke in two I didn't get off work until late so gonna try to go get a new cable tom. Let me ask you something this couldn't be cause by me changing the 3 springs that hold the belly buster weights together would it????
I put a stiffer spring on it.
Old May 20, 2003 | 11:42 PM
LT80's Avatar
LT80 Expert
Absolutely not
