Supertrapp exhaust Problem
Old May 16, 2003 | 10:11 PM
bigmval's Avatar
Default Supertrapp exhaust Problem
I had just put in The K&N Power kit and took her for a rip Wow what a difference. Now I will need new tires just to keep the power to the ground at launch. Anyways I was running 12 disks in the exhaust and finding it rather loud for the congested areas I was riding and wanted to try dropping it down to 8 disks to see what difference in noise and power I would see.
Thats when everything went to crap I broke one of the 3 screws used to hold the restictor plates in .[img]i/expressions/face-icon-small-sad.gif[/img] When I tried to grab with pliers to turn out the broken piece it is like a nut on the back side came loose because now all it does is wobble and spin.
I thought you took these things apart to repack so I figured I would pull apart and figure out how to fix. I can not pull out the core. I tried everything, putting the two good screws back in and pulling on them to no avail. I then removed the inlet pipe and tried to beat it out with a nylon bar and a hammer but no luck. Short of mangling pipe I could only get it to move 1/16th or less.
Do they come apart and if so HOW!!!! Any tips would be appreciated. I would hate to have to buy new exhaust for a broken screw![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old May 17, 2003 | 08:07 PM
ftwflh's Avatar
I cant get my scanner working but there is a retaining pin down by the clamp.And there is a buttonhead screw holding the core in at the other end.
Old May 17, 2003 | 10:06 PM
bigmval's Avatar
Thanks, I did get it apart, just needed bigger hammer. The retaining pin did screw me up. I hope I never need to do that again.
Old May 25, 2003 | 08:42 PM
skidder's Avatar
Greeting fellow mud things
A bigger hammer is the right tool in a lot of cases. [img]i/expressions/face-icon-small-wink.gif[/img]
turn me loose
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Mojave250A
Jul 11, 2015 10:38 AM
cSchwartz
Jul 9, 2015 02:43 PM
