headlamp 2000 scrambler?
Old May 17, 2003 | 11:19 PM
HAZ's Avatar
HAZ
Default headlamp 2000 scrambler?
My headlamp went out today and the dealer said i could not just replace the bulb i had to replace the hole headlamp for $44. can i just replace the bulb?
Old May 30, 2003 | 11:50 AM
Scrmblerman's Avatar
I took my bulb housing out the other day on my 02. I would think the bulb would just pull out (I did not try it). It is very easy to take it out of the head light. I would try to take yours out before paying that much for the whole thing.
Old May 30, 2003 | 01:03 PM
BigBadScrambler's Avatar
The bulb itself can come out. I took mine out and with some modifications replaced them with the Cool blue bulbs #9007 for an automobile. They were only $15 a piece.
Old May 30, 2003 | 02:06 PM
jtrundle's Avatar
where did you get the cool blue bulbs?????
Old May 30, 2003 | 02:40 PM
I got this from harescrambler
go to your local auto parts store get sylvania part#9007 cool bulb cost 14.00 modifcation required make sure the high beam watts are no larger than 55watts or you'll melt the lens pull the old bulbs out of the plastic housing next take the new bulbs out of there housing you have to dig the silocone out careful not to touch the bulb use rubbing alcohol to clean it if you do straightin the leads out on the new bulbs compare them to the old bulbs bend the leads where they need to be bent cut remainder off insert into old bulbs plastic connector the way you took the old ones out they work better than originals
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
