how to get high R's on the scrammy
Old May 18, 2003 | 05:48 PM
polarisman72's Avatar
Default how to get high R's on the scrammy
Is there any way to be able to turn some hellish R's on a 01' scrammy 500 4x4. I was just curious as to what some of you guys do with your machines
Old May 18, 2003 | 09:04 PM
scramblered's Avatar
a different clutching setup will help,but it doesn't make sense if you're running stock pipe,remember the 500 scrambler engine break at 6800 rpm.
Old May 18, 2003 | 09:10 PM
I got a clutch kit and a pipe, i was thinking bout like a 40mm flat slide carb, ported maybee, i dunno what else
Old May 19, 2003 | 04:34 AM
2002Scrambler4x4's Avatar
Polarisman 72
Please keep posting if you do get the 40mm carb and how it works out for you. I also have a Scrambler 4x4 with a clutch kit, header, and pipe, and I would really like to know if it's worth it. I think unless you start to bore and port the engine, (which I'm not convinced is worth it, I'll just buy a different quad instead!) that's about as far as you can go with the Scrambler. Although I'm not sorry I bought my Scrambler, it's frustrating that with the exception of 1 or 2 companies there is no aftermarket support. I think we Scrambler 4x4 owners will just have to be content with our smug knowledge that we have 4x4 on our sport(y?) quad. So there... phppht!
Old May 19, 2003 | 11:51 AM
polarisman72,i think you should for the hot seat 42mm carb,it is proven to work best on the 4 stroke 500,try to get clean clutchs and good running belt to make sure thr r's are all the way to full shiftout.
Old May 19, 2003 | 11:18 PM
I know if i get a new carb my buddy can port it in his shop for me for no charge, how much do them 42mm's run for
Old May 19, 2003 | 11:20 PM
Wow thats pretty expensive, i know i could get the 40mm for aroung 190 is it that much of a difference
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
