400SP shifting problems!!
Old May 19, 2003 | 12:33 AM
TJ400's Avatar
Default 400SP shifting problems!!
Last weekend I experienced severe problems shifting.... I managed to get shifted into low but then could not get out of low.... I then disconnected all linkages and moved the shifter through all possible positions.... I then reconnected all linkages and it's worked fine ever since..... The idle was low enough since I even tried shutting the engine down just to shift.... That didn't help.....
Has anyone any suggestions as to why this would happen.... I am afraid this will happen again in the futue although at the moment it seems fine...Is this a polaris bug that I simply have to live with?.....
Thanks for any help regarding this...
Old May 28, 2003 | 10:28 PM
TB400's Avatar
well this has happened to me before too but what you probably did was gave it gas when you where shifting which cause my shifter to freeze in place
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
