Red Spring & Holeshot
Old May 19, 2003 | 03:15 AM
Dan650's Avatar
Default Red Spring & Holeshot
For those of you who have the Red Spring installed and are getting the DG Holeshot module, are you going to remove the red spring when you install the module? Does anyone know at what RPM the red spring engages?
Old May 19, 2003 | 04:46 AM
Haynes1111's Avatar
I was planning on removing my red spring prior to installing the holeshot module. I did not find enough benefits of the red spring to warrent keeping it. It is manageable ect but wasn't nearly as smooth as the original.
Old May 19, 2003 | 08:44 AM
NovaKaw650's Avatar
I pulled out the red spring and put in a Dalton plain/white stripe spring. The EPI red engaged at about 1800 RPM and the Dalton runs at about 1500-1600 RPM's, stock is about 1300. Put in the Dalton or the stock spring when you get the Holeshot module, if you don't like the engagement of the red spring.
Old May 19, 2003 | 07:04 PM
Scotia650's Avatar
I have the module and the red spring installed and don't mind the engagement at all.
STLyamwar
Jul 25, 2020 04:44 AM
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Mphillips
Jul 2, 2015 07:20 PM
