tire size
Old May 21, 2003 | 12:32 AM
oneandonlyfloyd's Avatar
Default tire size
what is the biggest tire that can fit on the prairie 650 stock with no modifications?
Old May 21, 2003 | 12:36 AM
RaaaaddddChad's Avatar
Default tire size
I've got 26x9, 26x12 Kenda Bearclaws on mine with no problems. Awesome tire.
Old May 21, 2003 | 12:45 AM
Default tire size
thanks i am looking to see if i can get liek 27's with out much work if any even soem 28;s if posibale but i am almost sure it i will have to do somethign to get the 28's up there
Old May 21, 2003 | 02:06 AM
MURPH1's Avatar
Default tire size
you can fit 28"s but if you run outlaws or vampires i belive they will rub on the gas tank .
Old May 21, 2003 | 02:22 AM
PRAIRIEOUTLAW's Avatar
Default tire size
I run 26" Outlaws and they had to be shaved on the inside by the gas tank. If you run ITP 589's then you are good up to a 27" tire without mods to the suspension. It basically depends on the width of the rear tires and what type of tread on the outside and inside of the shoulders of the tires. Hope this helps.
Old May 21, 2003 | 12:52 PM
Default tire size
thanks yall been a great help
Old May 21, 2003 | 11:15 PM
mudhound's Avatar
Default tire size
Another thing is with no lift with 27 or 28 tires when the front wheels are cranked you will end up hitting against the inner wheel wells
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
