HERE IS SOMETHING YOU ALL NEED TO CLEAN
Old May 22, 2003 | 01:07 AM
CatKrazy's Avatar
Default HERE IS SOMETHING YOU ALL NEED TO CLEAN
ALSO WHEN YOU ARE DONE APPLY SILICON AROUND THE TIP OF THE OPENING AND THEN PUSH THE PULL HANDLE AROUND IT. THIS WILL PROVIDE A GOOD BEAD OF SILICONE EVENLY AROUND THE CAP. ALSO IF YOU CHECK THE BOTTOM OF YOUR RECOIL STARTER YOU WILL NOTICE AN OPENING TO ALLOW WATER AND DEBRIS TO RUN OUT. PUT A DAB OF SILICONETHER ALSO. THIS IS A VITAL PLACE FOR MUD,SAND,WATER AND OTHER MOTOR EATERS TO EANTER INTO YOUR CRANK CASE. ALTHOUGH THE CATS ARE SELAED UP PRETTY GOOD PRECAUTION IS ALWAYS GOOD.
ENJOY
CLICK
Hankey Pankey
May 1, 2018 01:33 PM
Jenn1
Sep 8, 2015 09:16 AM
WilliamBos
Aug 8, 2015 07:26 PM
WilliamBos
Jul 25, 2015 02:41 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
