help!!!
Old May 22, 2003 | 03:01 AM
Hotrodtyler's Avatar
Default help!!!
I have a '93 polaris trail boss that was reciently bored .040 over and new reeds put into it and now it willnot run for over ten minutes before quitting and having antifreeze come from the overflow tube. any ideas or suggestions?
Old May 22, 2003 | 08:55 AM
CED's Avatar
CED
Default help!!!
There is a bleed screw on top of your head that you need to crack open to let the air out of your cooling system.What was your piston clearance on your rebuild?.Sounds like it's getting hot very quick.
Old May 22, 2003 | 09:00 AM
CED's Avatar
CED
Default help!!!
You sure you put reeds in it ,the 250's don't come with reeds.Unless you have the reed conversion done to it.
Old May 22, 2003 | 09:18 AM
CED's Avatar
CED
Default help!!!
I'm sorry ,i had a brain fart.If it's a 250 it's not liquid cooled either.Oh well !!!
Old May 22, 2003 | 10:43 AM
vig's Avatar
vig
Default help!!!
Sounds like you either didnt bleed the radiator or you have a leaking head gasket. After warm up you and a good cool down your suppose to retork the base and head bolts. If you know the motor isnt hot when the antifreeze is coming out of the overflow then it is the head gasket. good luck.
Old May 22, 2003 | 04:26 PM
Default help!!!
It is the 350 and i checked that antifreeze is comming out of the overflow tube. I was told that it may be my water pump but i don't know changing that is supposed to be quite the job.
Old May 22, 2003 | 05:20 PM
CED's Avatar
CED
Default help!!!
Get yourself a manual it's not that hard at all.
Old May 22, 2003 | 10:44 PM
Bubba297's Avatar
Default help!!!
It is a very common thing for people to put a head gasket on upside down (I have been guilty myself). It will cause it to bleed compression over into the cooling system. But as said before retorque it first.
