Carb-mounting a K&N airbox filter???
Old May 25, 2003 | 05:43 PM
TyreSpinner's Avatar
Default Carb-mounting a K&N airbox filter???
Hey guys,
I currently have the K&N in the stock box. I was wondering if it's possible to carb-mount it without buying a new filter?
Thanks
Old May 25, 2003 | 10:13 PM
Eaglecollector's Avatar
I would say no. The one that goes into the air box is not only physically to big but the opening that would connect to the carb is way, way to big. Also the one that mounts on the carb nedds to angle down a little to help clear the seat. And even then it's very, very tight fit.
Old May 25, 2003 | 10:25 PM
Okay, it's gonna stay in teh box then.
Thanks Eagle (Larry is it??)
Old May 25, 2003 | 10:33 PM
LOL..yes and your welcome. You will gain about 2 ponnies by getting the carb mount K&N though. I think there about 35 bucks plus another 10 to 12 for the outerware.
Old May 26, 2003 | 12:07 PM
modquad's Avatar
Hyper Racing sells the slip-on K&N Ru-1770 for only $23. Slightly angled down, and 1" longer than the RU_1760, if things are too tight, maybe that one will work. Don't believe them if you ask for a water resistant Outerwear though, they'll still send you a regular one. Order the WR Outerware straight from Outerwares.
Old May 26, 2003 | 12:12 PM
Does anyone use the carb mount filters for muddy and wet conditions and snow...we have all of the above here...And I'm hesitant to get a carb-mount fearing water or crud getting into my engine.
Thanks
Old May 26, 2003 | 03:44 PM
DSJOBBER's Avatar
Dont forget the cost of the duct tape Eagle. Well thats what your gonna need to repair the holes in the outerware. Tight fit is putting it mildly.
Old May 26, 2003 | 05:07 PM
LOL....Very, very true add 6 bucks for duct tape (AKA race tape)
Old May 27, 2003 | 12:52 AM
dunesled's Avatar
The best way to make one fit is to chop the plastic on the bottom of the seat. After wearing through 3 outerwears through 3 rides I decided to chop the plastic. Problem solved.[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 27, 2003 | 01:02 AM
jeffnrivercity's Avatar
You can try this trick...................
I have seen this done with the box removed.......with good results
Just remove the box and leave the filter,tube and rubber coupler.
Then make sure you have an outerwear on the filter then.
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
