Sportman 90 Wont start (MUD!)
Old May 25, 2003 | 10:20 PM
Sportmanrider90's Avatar
Default Sportman 90 Wont start (MUD!)
TOday i went quading and my quad is all messed up (sportman 90 CDI)(2 Stroke). Ok well i was quading in MUD! lots of it. and if u ever saw a sportman 90 the filter thingy is right by the front tire. well i was idling there for a little bit and the quad stalled and wouldnt start. so i brought it to a place there and they cleaned the filer becuase of the mud. So i countiued riding and the same thing happened. We got pretty fed up so we went home. We fixed it again and it worked find *before dinner*We came back from dinner and it wouldnt start. We tried to clean the filter and bolt it back on. I think the problem is that dirt got in the piston and carbertor. Could this be? Also would i need to get a new piston and carberator?? THanks in Advance
Old May 25, 2003 | 11:27 PM
foreman450cc's Avatar
Well 1st off dont take a 90cc quad in the mud they just not made for that. 2nd buy a kit or weld somthing to cover the front like a metal plate or somthing like that.and if u got mud in ur carb or piston thats really bad u gotta clean it good.
Old May 26, 2003 | 10:52 AM
Could i just un bolt it and clean it out
Old May 26, 2003 | 11:29 AM
Also do u think its from the Jets now with the warmer weather?
Old May 26, 2003 | 11:45 AM
unbolt the filter? yeah that will work but if u got mud in your carb that can cuase probelems so make sure you clean then both good. I doubt any mud got in ur engine. just hose it off good and clean the filter and carb. it should start right up then.
Old May 26, 2003 | 10:01 PM
Could i get the piston wet or no?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
Dylan.11
Utility ATVs
Jun 4, 2015 03:58 PM
1000gade
May 27, 2015 12:37 PM
