Carb rebuild kit 250r atc
Old May 26, 2003 | 12:42 PM
Bigmo2u's Avatar
Default Carb rebuild kit 250r atc
I am looking for a carb rebuild kit for a 250r 3 wheeler 1985. Where is a good place to get one and how much should I be paying for it?
Old Dec 9, 2003 | 04:22 AM
HELLBILLYAL's Avatar
Try EBAY under Honda ATC 250r I think they go for $15 to $40 somewhere in that ballpark good luck
Old Dec 9, 2003 | 10:31 AM
NichelsonRacing87's Avatar
it should be close to the same rebuild kit as the TRX250R
Old Dec 9, 2003 | 11:32 AM
trx250Rob's Avatar
Be very weery about buying a stock used carb. The valve seat on the stock 85-86 ATC and 86-89 trx 250r are not replacable. This means that if it starts leaking gas from the overflow line, and you replaced the valve, the carb is junk. This is very common with these carbs.
I suggest you buy a new carb, the $120 is worth the headaches you will go through.
GregM
Mar 6, 2018 06:53 AM
kelleycully
Sep 15, 2016 02:57 AM
CRamshaw777
Jul 18, 2015 05:46 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
yambam13
Jul 4, 2015 01:49 PM
