300ex CDI problem?????
Old Dec 7, 2003 | 11:30 AM
Rangerrick63's Avatar
Default 300ex CDI problem?????
My son has a 95 300ex that just started a problem, or at least I think it is a problem. I just put a Cobra exhaust system on, & rejetted the carb up to a 155 main jet. Now it cuts out at a much lower RPM than it used to. It sounds like it is up against the rev limiter, but if he short shifts it, it seems to do fine, but he really looses alot in the turns with this. My question, can this possibly be a problem with the CDI unit. I was considering purchasing an aftermarket CDI box with a higher RPM limiter. Or did I miss the mark on the main jet? It doesn't seem to be running rich, so I have set aside the possiblity of the main jet being too big. Any help with this will be greatly appreciated, thanks
Old Dec 7, 2003 | 03:03 PM
I just realized I said I put a 155 main jet, sorry, it was a 135 main jet. Hope someone can direct me in the right direction on the problem.
Old Dec 7, 2003 | 03:09 PM
95wolv's Avatar
There's nothing wrong with your cdi, it's just that Honda put an ungodly stingy low limit on the stock cdi rev limit.Your engine is now breathing better,and revving easier,so you are hitting the limit sooner, ran into the same problems on my son's, actually ran slower with the shorter tires and mods, putting a 14 tooth front sprocket in place of the 13 factory helps a lot, and is cheap. I ended up getting a modified cdi with the limit removed, so he can use all the power . Try a 14 tooth up front, should help a lot, and give him better top end to boot.
Old Dec 7, 2003 | 03:14 PM
Thanks, for the advice, the 14 tooth sprocket will be on this week. I was hoping that there was nothing wrong with what I did. Thanks again
Old Dec 7, 2003 | 06:43 PM
TheQuadSport230's Avatar
Is 135 main jet a keihin jet or dynojet?
Old Dec 7, 2003 | 08:58 PM
It is a Klein, I tore the carb back down this evening, & switched the jet to a 130. After racing last night, & riding at the practice track a couple of hours today, I pulled the plug, it looks like it is running rich. I also will be going up to a 14 counter sprocket, & will see next weekend how it goes. Thanks
Old Dec 8, 2003 | 11:35 PM
TractorPacker's Avatar
Do you have a balloon?
I am thinking the main for just a pipe is a 128, or with a filter. The 135 is a huge jump for that little engine. Our 300 is a 305 big bore and never went over a 132, before the 400ex carb. Oops did I just give up a huge secret?
The 35.5mm carb bolts right up.
Old Dec 9, 2003 | 12:26 PM
The 400ex carb will work on the 300? Is it a direct replacement, or does the throttle cable have to be swithced?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
