chain clatter
Old May 28, 2003 | 10:57 AM
predator530's Avatar
Default chain clatter
has anyone figured out how to stop the chain from clattering on the predator? it really is annoying thanks
Old May 28, 2003 | 11:30 AM
pudljumpr's Avatar
Check your chain tension. With the concentric system, the chain can be pretty tight, tighten it up and it should run a little more stealth. Or get a little bigger sprocket in the rear, this also helps a little...such as a 38T
Old May 28, 2003 | 12:58 PM
thanks pudljumpr i will try that but i have tightened the chain but no results with out counting my teeth on the front sprocket what size is it
Old May 28, 2003 | 01:54 PM
modquad's Avatar
Stock gearing is 14/37. You can get the 38 in shiny red from Polaris, and a 13 tooth from Sprocket Specialties.
Old May 28, 2003 | 04:24 PM
pudljumpr's Avatar
Yes, what modquad said. But if you want to keep the top end, get the 38 rear and keep the stock 14 front...I definately noticed the chain rattle was gone after I put the 38 on, the only thing I could hear then was my chain roller and my sweet engine[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 28, 2003 | 05:49 PM
thanks guys
Old May 28, 2003 | 07:30 PM
pudljumpr's Avatar
Anytime!
Old May 28, 2003 | 08:03 PM
nccracing's Avatar
I just installed one of those shiny red 38t rear sprockets on mine. But I havent tried it out yet.It looks faster just because the color.. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 28, 2003 | 08:06 PM
cool!!! if i paint flames on my sprocket will it go faster too?
Old May 28, 2003 | 08:09 PM
nccracing's Avatar
It will and the only ones that will see it is the rappys because they will be behind you.. [img]i/expressions/face-icon-small-blush.gif[/img]
