replacing torn inboard boot
Old May 28, 2003 | 02:44 PM
timetogo's Avatar
Default replacing torn inboard boot
I'm in the midst of replacing an inboard boot on my TRX300FW. I've taken off the wheel, brake drum, removed the tie rod, and lower arm. I was hoping to be able to rotate/lift the knuckle/brake panel assembly enough to slide out the drive shaft from the outboard side then pull it out of the differential. The kuckle/brake panel assembly can only be rotated about 20 degrees from vertical which isn't enough to remove the drive shaft. Anyone out there been here before? Do I need to remove the upper arm as well?
Old May 28, 2003 | 03:19 PM
timetogo's Avatar
Folks, I'm all set ... I removed the shock absorber and it gave me enough play [img]i/expressions/face-icon-small-smile.gif[/img]
MooseHenden
Polls
33
Aug 28, 2015 04:56 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
Gtsordo
Jul 22, 2015 01:27 PM
