Rear shock adjustment
Old May 28, 2003 | 07:19 PM
CaptDrydock's Avatar
Default Rear shock adjustment
How do you know what is the correct rear shock adjustment for the load? This would be for a Sportsman 500 HO.I have read that you should use a stiffer setting for climbing hills?
Old May 28, 2003 | 07:36 PM
fullthrottle's Avatar
Whatever feels the smoothest when riding.
Old May 28, 2003 | 10:22 PM
Guys; Any more help or suggestions on this question???
Old May 30, 2003 | 09:26 AM
Again, Adjust the collar ride it, adjust the collar again ride it till you finally find a setting you are pleased with. A stiffer setting may or may not be right for you. Its all in the rider, or should I say alot has to do with the rider.What is the year of your machine? I am going by a SINGLE SHOCK adjustment which I have. Your ride is probably an independent rear . Let me kow what you come up with. Maybe someone else can better answer your ? Hope I helped even if just a little?
Old May 30, 2003 | 10:49 AM
Fullthrottle:Thanks for the reply.I will take it up two notches and test ride it,and yes my machine does have independent suspension.I'll let you know of the outcome. regards,Capt.Drydock
Old May 31, 2003 | 10:41 AM
SpruceDuece's Avatar
What is the easiest way to turn those collars....my tool kit didn't come with a spanner wrench.
SpruceDeuce
Old May 31, 2003 | 10:45 AM
csamayfield55's Avatar
I asked my dealer about a spanner and he said it was about 30.00 so I just used a pair of channel locks and a rag. I set mine up 2 notches for trail riding but will go up one more if I have a load.
Chris
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
