300ex rear bearing ?
Old May 28, 2003 | 09:56 PM
rodman922's Avatar
Default 300ex rear bearing ?
i need to put rear bearings and seal in was wondering what do i need to pull off the sprocket spline or the brake spline b4 i slide the axle out?
thanks
rodman
Old May 28, 2003 | 10:05 PM
KILLER250R's Avatar
Do a search, there was a post about taking the axle out of the 300EX last week.
Old May 29, 2003 | 04:02 AM
hondaracer305's Avatar
Just the spline, and it should slide right out.
Old Jun 3, 2003 | 04:19 AM
Weed15's Avatar
I just put a Lonestar bearing carrier in my 250x, which has the same swingarm and bearing carrier as the 300ex, and all I did was took off the axle lock nut , the right rear wheel and hub, brake rotor, the rear brake caliper holder and axle slid right out. Then just take the bearing carrier out and change out your bearings and seals. Later, Good Luck
STLyamwar
Jul 25, 2020 04:44 AM
Asaran
Oct 8, 2015 11:14 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Peter_
Jul 18, 2015 07:06 AM
