P650- New belt, black spring, 200 miles and squeekin again>>
Old May 30, 2003 | 12:28 AM
lackdog's Avatar
Default P650- New belt, black spring, 200 miles and squeekin again>>
the topic sums this up. I got a new belt and a black spring and rode 200 miles and now the belt is sqeekin at takeoff again. Is this a shim problem now?? To remove the shims do I just take appart the secondary like normal when I put in the black spring? I never actually separated the seconday. So do I just pull out the 4 pucks and it comes appart or is there another special tool for that? Any help appreciated
Old May 30, 2003 | 12:51 AM
Wolley's Avatar
Yep just pull out the pucks and then separate the sheave halves. Spacers will be between the two halves. Check your belt deflection first. If I remember each .1mm of shim equals about a 1/16th of an inch deflection. So if you have 1.5 inches of deflection and you take out the .6mm shim then your deflection should go to about 1 1/8th inches.
Mark the outside of each sheave half before you take em apart so that they can be reassembled in the same orientation.
Nyroc's site has a much better description and pictures to illustrate this procedure.
Old May 30, 2003 | 08:23 AM
trx450's Avatar
Yep, the belt is too loose. The technician that installed the new belt may NOT have set up the deflection correctly, OR the new belt stretched a bunch. The belt stretch is unlikely. Another thing that saves on belt/pulley wear is: Run the bike in "LOW" range for tight woods riding. I keep mine in low, when running consistently under 20 MPH. I should get about 3K miles out of my original belt. I have 2K miles on it now. From experience, I would say that you will need a .6MM THINNER shim than is in your driven pulley now. GOOD LUCK!
mtdewmn
Jan 19, 2017 12:13 PM
toonces
Jul 31, 2015 09:27 AM
Schneider
Jul 24, 2015 05:05 PM
WilliamBos
Jul 22, 2015 04:20 PM
trouttracker
Jul 20, 2015 11:54 AM
