Should i change the spark plug on my foreman?
Old May 31, 2003 | 04:04 PM
RedneckE's Avatar
Default Should i change the spark plug on my foreman?
I have a 2000 foreman 400 4x4 that i do a lot of work with, and just trail/mud riding, and i have never changed the spark plug on it, and i was wondering if i need to, or if it would help it run better or anything.It runs just fine right now, and has no mods.. What kind/size/brand should i get if i decide to get a new one?Is it easy to change on a foreman?Thanks for any help.
Old May 31, 2003 | 09:35 PM
KILLER250R's Avatar
They are very easy to change, pull of the plug and turn counterclockwise. As for which plug to run, look at the numbers and letters on your current plug then go to the store and get whatever those numbers say..get an NGK plug..those splitfire's and all these other plugs are just a joke...if they really helped everyone would be running them.. On a fourstroke I changed the plug every six months wheather it needed it or not...and it's less then $2 so it's not like I am out a lot of money for changing it. Also before you put the new one in mak sure it has the correct gap...don't just throw it in straight out of the box...refer to your owners manual for the correct gap.
Old May 31, 2003 | 09:38 PM
RedneckE's Avatar
Thanks killer250r, anyone else have any suggestions.
Old May 31, 2003 | 11:17 PM
RedRancher's Avatar
On all my old bikes I changed the spark plug(s) at least once a year, I recommend you do the same. Killer250R explains changing a spark plug best so refer back to his reply on how to do it.
Old Jun 1, 2003 | 03:08 PM
SporkBomber's Avatar
Killer explains it perfectly well. Just make sure you have the correct gap on the spark plug, that is essential with all engines.
Old Jun 1, 2003 | 03:18 PM
RedneckE's Avatar
Thanks for all the help guys.
Old Jun 1, 2003 | 07:02 PM
dzzy's Avatar
I wouldn't replace it unless it's showing a bit of wear. Look at the electrode and if the sides are nice and square yet, if so, leave it. ALWAYS have a spare around tho.
Old Jun 2, 2003 | 09:37 AM
95wolv's Avatar
dzzy, a plug can go bad without being all used up or looking worn, so a yearly replacement is cheap insurance against sudden failure or lost performance. The only thing I have to add is to put a dab of anti-sieze on the threads to prevent any galling of the threads or ruining the threads in the motor,which is softer than the plug.
Old Jun 2, 2003 | 02:59 PM
dzzy's Avatar
Very true, but that is when the plug is fouled, and that can happen to a new spark plug as easily as an old one IMO.
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
