2002 400ex rear master cylinder :( :disgust;
Old 06-01-2003, 03:27 PM
SixtyNine400ex's Avatar
Default 2002 400ex rear master cylinder :( :disgust;
I think my rear master cylinder is blown b/c when i changed my brake pads I put some red harley brake fluid in there I dont think I should have. Now ehn I take the cables off & peer down inthe the master cylinder the brake fluid doesnt come to the top.....I also have no back brakes & have tried bleeding them with bleed gun & everything. Is that what happend or is there something else? How much is a rebuild kit or do I have to buy a new one? Thanks
Old 06-02-2003, 01:08 AM
ttt
Old 06-02-2003, 09:29 AM
dzzy's Avatar
That was a mistake. Harley uses DOT5 silicone brake fluid. Yours calls for DOT4. I don't think they're compatible! Plus, the silicone stuff is a lot harder to bleed. It can be a real battle. Drain that stuff out as completely as possible. Remove the line and blow it out, remove the caliper and hold it upside down, unbolt the m. cylinder and do the same. Rinse them out with brake cleaner, I use the Honda stuff as I know it's ok with the materials. Replace it with a DOT4 fluid. When you get it bled up, run a bunch of fluid through it. Unless you got a major leak somewhere, try that first before you go and buy all sorts of parts.
Old 06-02-2003, 01:14 PM
alright thanks man....thats exactly what I wanted to hear...& also, do they sell a rebuild kit for the 400ex mster cylinder or am I gonna have to get a whole new one....the back caliper should be okay right?
Old 06-02-2003, 03:05 PM
dzzy's Avatar
Honda sells master cylinder repair kits but I haven't checked specifically on the 400ex. I would be surprised if any damage was actually done though.
XxS0ccerstarxX
10-18-2021 10:03 PM
SixSpeed5
8
08-02-2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
08-01-2015 04:05 AM
Sandman2.0
07-21-2015 09:03 AM
MNatv89
07-07-2015 11:36 AM
Quick Reply: 2002 400ex rear master cylinder :( :disgust;
