BROKEN SHOCK
Wow, you must be getting some big air. The only thing i ever broke a shock on was a wolverine. But then again I was also jumping it 8ft in the air and landing on flat ground, anyway I would recomend some works at steelers dual rate set up for motocross. I have a brand new banshee and it is in the shop right now because I got a little too high myself/
Jon--2000 blue and white Banshee-rental bars-holeshot tires
I to have busted one of my front shocks .So I decided to up grade my suspention.I just ordered them yesterday ,I got the works steelers with daul rate springs and adjustable resavors for568.And since I got the new fronts coming in ,I also got the rear duracross mono shock with the threded preload and rez with full adjustments for 689 .I thought I would be paying alot more so i had some money left and decided to get a denton staring dampener and a complete set of thor flow jersy and riding gear . If your going to buy shock ,may I sudjest purchasing then from graydon proline the have exilent servess and will custome valve the shocks free of charge ,And I found that there 20-50$ cheaper then every one else when it comes to shocks. sorry about my spelling
My shocks broke of at the bottom weld. i am lucky it is still under warranty. They are sending me new shocks and i heard from my dealer that yamaha made some defected shocks.
If anyone is in need, I have a pair of front stock shocks for sale off a '93 warrior. Let me know
Does anyone know of a place to get the rear stock shock revalved? $600 is a bit steep for a new ultra-cross rear shock. Ouch!
Yep!! I broke me shock down there on the bottom weld. I took it to the dealer for them to look at it and they welded it right there for under $30. Not bad considering a new one cost like $120. So, its just as strong, if not stronger than b4.
Try calling Total control suspension, there # is 562-945-4473. But beware I've talked with them and Works and everyone is behind on building shocks. I just recieved my Ultracross shock for my warrior yesterday, I ordered it the 3rd week of February. Good luck.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
