BROKEN SHOCK
Old May 7, 2000 | 06:48 PM
99_warrior_350's Avatar
I have a warrior and busted two front shocks already. I wanted to know if anyone else had this problem. And i want to replace them with works or some other kind of shocks.
Old May 7, 2000 | 07:13 PM
scotch54's Avatar
Wow, you must be getting some big air. The only thing i ever broke a shock on was a wolverine. But then again I was also jumping it 8ft in the air and landing on flat ground, anyway I would recomend some works at steelers dual rate set up for motocross. I have a brand new banshee and it is in the shop right now because I got a little too high myself/
Jon--2000 blue and white Banshee-rental bars-holeshot tires
Old May 7, 2000 | 09:43 PM
I was only jumping 5 foot.
Old May 7, 2000 | 10:48 PM
scotch54's Avatar
WoW, something must be majorly wrong, good luck in fixing it
Old May 9, 2000 | 11:11 AM
97warrior's Avatar
I to have busted one of my front shocks .So I decided to up grade my suspention.I just ordered them yesterday ,I got the works steelers with daul rate springs and adjustable resavors for568.And since I got the new fronts coming in ,I also got the rear duracross mono shock with the threded preload and rez with full adjustments for 689 .I thought I would be paying alot more so i had some money left and decided to get a denton staring dampener and a complete set of thor flow jersy and riding gear . If your going to buy shock ,may I sudjest purchasing then from graydon proline the have exilent servess and will custome valve the shocks free of charge ,And I found that there 20-50$ cheaper then every one else when it comes to shocks. sorry about my spelling
Old May 9, 2000 | 09:14 PM
PC_350_Warrior's Avatar
I've also broken a front shock on my Warrior. I broke the right-front. Depending on where it broke, you could get it welded. Thats what i did, but i might buy worx shox anywayz. Where did it break??
Old May 9, 2000 | 09:42 PM
My shocks broke of at the bottom weld. i am lucky it is still under warranty. They are sending me new shocks and i heard from my dealer that yamaha made some defected shocks.
Old May 10, 2000 | 07:36 PM
Heapster's Avatar
If anyone is in need, I have a pair of front stock shocks for sale off a '93 warrior. Let me know
Does anyone know of a place to get the rear stock shock revalved? $600 is a bit steep for a new ultra-cross rear shock. Ouch!
Old May 10, 2000 | 08:15 PM
Yep!! I broke me shock down there on the bottom weld. I took it to the dealer for them to look at it and they welded it right there for under $30. Not bad considering a new one cost like $120. So, its just as strong, if not stronger than b4.
Old May 12, 2000 | 12:29 AM
fourstroke's Avatar
Try calling Total control suspension, there # is 562-945-4473. But beware I've talked with them and Works and everyone is behind on building shocks. I just recieved my Ultracross shock for my warrior yesterday, I ordered it the 3rd week of February. Good luck.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
