difference between a 10-58 and s-58 weight
Old Jun 4, 2003 | 06:57 PM
trenchdigger's Avatar
Default difference between a 10-58 and s-58 weight
could someone tell me the difference between these weights and which might be better to use on my 400 xplorer when pulling a weight transfer in a pulling contest (or maybe someone could tell me agood clutch combination for this application). I have a EPI sport utlity clutch kit in it right know.
Old Jun 4, 2003 | 07:28 PM
POLARISFREAK's Avatar
An s58 will pull harder off the line.
Old Jun 4, 2003 | 08:23 PM
fullthrottle's Avatar
Sorry I cant help with your question but, may be you can help me? I have the same clutch kit and was wondering what weights they use with this kit. I dont remember. I just didnt want to take it apart to find out. How do you like the kit? What year machine ?
Old Jun 4, 2003 | 08:28 PM
scramblered's Avatar
10-58 weights are HEAVY HITTERS weights,heavier tip so it will pull harder on acceleration cauze of less belt slippage,recommended on high HP engines.s-58 are non-bushed weights,that mean they have lighter tip for more throttle response through the range and faster revving,recommended on lower torque hp engines.
Old Jun 4, 2003 | 08:38 PM
So what your saying is our 400 would be considered a lower torque hp machine?
Old Jun 4, 2003 | 09:03 PM
fullthrottle the weights are 10-58 ,the primary spring is red, driven clutch spring is purple,it seems to work pretty good i have a set of s- 58 weights from aaen that have been ground and the kit seems to work better when i put them in lots of low end but i think i lose some on the midrange and topend.
Old Jun 4, 2003 | 09:10 PM
i forgot to tell you it is a 2000, k&n filter, 20 thou weisco piston, dual stage reeds, 10 thou shaved off head ,just finished total rebuild on engine
Old Jun 4, 2003 | 11:02 PM
trenchdigger, Thanks for the info. A friend of mine has the 2001 xplor 400 and has been playing with springs and weights and is still yet to keep up with me. I am carrying between my winch my cargo bag, atrs on c-series and 20# xtra body weight =close to 80xtra lbs. All he has done is put boysen reeds in and played with weights and springs. Im not blowing him away but, I sure am pulling away I keep telling him to go for the clutch kit and stop farting around but, hay he must be happy eating my dust.
Old Jun 5, 2003 | 12:05 AM
what mods done to the quad?
when i said lower torque engine it was reffering near stock trim,or slightly modded.
Old Jun 5, 2003 | 09:50 AM
fullthrottle i was wondering if you know what combinations your friend had tryed because i have been playing around with a bunch of combo"s and it is hard to tell what works better because i have nothing to compare it to , i have read on here that the best set up is just changing to the polaris white primary spring , i have tryed this but i think the epi kit is better. i go in a few atv pulls and it is amazing how well this quad in stock trim does against bigger quads,know that i have a few mods ,and if i can get get my clutching figured out for pulling it should do even better. thanks pol.freak & scramblered for the info.
