Needle/Clip Question
Old Jun 5, 2003 | 06:57 PM
pads's Avatar
Default Needle/Clip Question
I went back to the stock needle from a Dyno Jet Needle and am at second from the top. If I go to the third I absolutely can't wheelie. When I go back to the second everything seems fine. Does moving the clip make that drastic a change? Has anyone else had problems with the Dyno Jet Needle?
Old Jun 5, 2003 | 07:31 PM
BigDaddy331's Avatar
Absolutely! Those little changes make a big deal. What are you running for a needle? You might even try some different needles just to make sure you are right on the money.
Old Jun 5, 2003 | 07:33 PM
Hightower's Avatar
stock needle original position was 4th groove, so you're needle position is way leaner than you were stock now. when I ran stock carb I moved to the dynojet needle and me and most others liked it much better. it sounds like you may be rich on the main, or perhaps a float issue, but then again maybe its the nature of your beast and altitude.
Old Jun 6, 2003 | 07:06 AM
pads's Avatar
When I ran the Dyno Needle it would produce the same bogging going up hills and when I tried to wheelie as having the stock needle on the third clip. My main is a Dy 185.
Old Jun 6, 2003 | 10:02 AM
fastone21's Avatar
It take alot of testing to get your quad stock carb spot on. YOu probably won't get it right the first time. So here is a few suggestions. Get a note pad and record settings and needle and jets positions and note the performance. Be wise to record the temperature. This way you don't have to rely on memory to find out which setup was the best. This helps me a lot hope it helps you.
Old Jun 6, 2003 | 10:00 PM
pads's Avatar
Thanks Hightower. My floats were way off. I just made the top of the floats level with the gasket surface. I went back to the Dyno Jet needle 2nd clip down. There is no hesitation like before and I can wheelie in 3rd gear. Thanks a lot for your help.
Old Jun 7, 2003 | 10:04 AM
Hightower's Avatar
Sweet, I really liked the dynojet needle better myself.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
