v force top end
Old Jun 7, 2003 | 11:24 AM
Kill4IDF's Avatar
Default v force top end
what is a some what inexpensive way of getting more out of the v forces top end. [img]i/expressions/face-icon-small-blush.gif[/img]
Old Jun 7, 2003 | 03:59 PM
KevinM's Avatar
Change to a stiffer primary spring that will allow the motor to rev higher and it won't fall off on top. $20 investment, 15 minute installation.
Old Jun 7, 2003 | 04:38 PM
Kill4IDF's Avatar
do u have a direct link where i can purcahse this [img]i/expressions/face-icon-small-smile.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 7, 2003 | 05:01 PM
KevinM's Avatar
The Polaris primary springs are the same and there is a much better selection. The stock Kawi spring is approx. the same as the blue/green Polaris spring and is rated at 20/90 which is much too mild for a 700 twin. I use the Polaris brown rated at 50/180, approx. 300 more RPM's stall and a lot better pull on top. The Polaris yellow rated at 40/190 should also work well.
Hotseat Performance
Old Jun 7, 2003 | 05:35 PM
bigcreek1's Avatar
Hey Kevin, do you gain any top end or just get there more quickly?
Old Jun 7, 2003 | 05:42 PM
Kill4IDF's Avatar
ya and how the hell do i get my hands on one :'(
Old Jun 7, 2003 | 05:58 PM
MnFriesen's Avatar
I have herd of a black spring also. what is the difference between this and the ones mentioned privously? and what kind of gain do you get from each
Old Jun 8, 2003 | 12:03 AM
KevinM's Avatar
Top speed on the V-Forces are as good or better than anything out there in my opinion, it just takes longer to get there than it should. The stock spring is the same as what Polaris puts in their 500 Scramblers and is a good way for Kawasaki to detune the V-force from the factory. With a stiffer spring you may gain a little top speed due to the extra RPM's you can pull on top, but the spring's main advantage is getting you to top speed quicker.
The black spring is used in the secondary clutch to put more tension on the belt giving less belt slippage.
Old Jun 8, 2003 | 12:54 AM
Kill4IDF's Avatar
thanks kevin, great help! now i am on the site what is the BEST spring? what color?
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
