cleaning engine and gear cases
Old Jun 7, 2003 | 07:55 PM
OffRder15's Avatar
Default cleaning engine and gear cases
Is there any way I can get my engine and gear cases looking better?
Old Jun 7, 2003 | 08:01 PM
CED's Avatar
CED
Clen them real good with some simple green.Then you can polish them,boy that's a job.Take a look at the j's in the gallery.Look at Jim Maloney's engine in his pic's.Aluminum polish works pretty good ,just doesn't last very long.Hope this helps.
Old Jun 7, 2003 | 09:57 PM
modquad's Avatar
There are some spray-on aluminum brighteners, but always test in an inconspicuous place, and since they're normally acid based, have water readily available.
Old Jun 7, 2003 | 10:37 PM
ftwflh's Avatar
I use a acid base cleaner made to clean coal trucks alluminum trailers.Dillute itt spray ,bush and rinse off.work good but test it first.
Old Jun 8, 2003 | 06:55 PM
OffRder15's Avatar
What's a good brand name and where can I find it?
Old Jun 8, 2003 | 07:15 PM
scrambler123's Avatar
i used some heavy metal polish on mine originally i was just going to clean them up but once i started i realized they were turning chrome so i had to polish for a long time to make it look good. if i was you i would just clean them.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Dabears1983
Jun 16, 2015 12:17 PM
merryman
Jun 15, 2015 02:36 AM
hugemoth
Jun 4, 2015 02:56 AM
hoopduerr
Jun 2, 2015 09:01 AM
