starter removal help
Old Jun 7, 2003 | 11:40 PM
scrambler123's Avatar
Default starter removal help
i am pulling my starter off to block it off i already have the battery out
so now i just unbolt the side case where the pull start goes in right?
i have all the bolts out but it doesn't seem to want to come off do i have to take the plugs that are on the top and bottom off first?
what kind of fluid is inside this case and will it come out when i take it off?
any help would be appreciated
Old Jun 8, 2003 | 01:16 AM
modquad's Avatar
There isn't any fluid in that chamber of the motor. Remove the bolts, and a little trick to make things quick....that's if you used to play hockey....or have a longer chunk of hardwood laying around. Assuming you're running a slip-on K&N, or at least have the airbox out of the way, there are a couple of protrutions on that sidecover you can angle the wood down (with the seat off) and give it a few taps. Seems to me there were fastener/or fasterners behind the rear clutch cover too.
Old Jun 8, 2003 | 01:33 AM
i got it all out just i just hit it a few times then struggled with the bolts but it wasn't too bad a couple people said they needed special tools but i didn't find that neccesary just normal end wrenches did the trick
Old Jun 8, 2003 | 01:36 AM
modquad's Avatar
Are you sending your flywheel to HPD to have them lighten it?
Old Jun 8, 2003 | 01:42 AM
i'm thinking about it
does it make a noticeable difference?
should i get it trail or race lightened?
i removed 31 pounds from my quad today between
starter,battery,mudflaps,sprocket guard, skidplates, lights, and bolts
should be quite a bit more after injection removed
Old Jun 8, 2003 | 09:10 AM
talonhawk's Avatar
I had the flywheel on my 99 TB race lightened and it made a big difference.
Faster throttle responce =[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 8, 2003 | 12:47 PM
modquad's Avatar
Like Talon said [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 8, 2003 | 10:44 PM
Sparks9999's Avatar
How did you get the starter off? Did you have to remove the clutch covers?
Thanks,
Sparks9999
Old Jun 9, 2003 | 01:16 AM
no i didn't have to remove the clutch i just removed the engine case where the pull start goes in.
Old Jun 9, 2003 | 11:51 AM
NCScrambler's Avatar
I had my flywheel HPD race lightened, it will put a big [img]i/expressions/face-icon-small-smile.gif[/img] on your face.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
