burning smell
Old Jun 8, 2003 | 09:20 PM
badass300ex's Avatar
Default burning smell
I have a 03 300ex with a full pipe,K&N, and its been jetted all work done by dealer.I decided to do a stage 2 on it and take the air box lid off and put new jet in. the dynojet kit said to put a 128 in and the mixture screw stays the same as it was in stage 1. heres the problem I took it out today for the first time since I changed the jet and removed the air box, idels good, good throttle responce and it ran good. After I got on It through all the gears and came to a stop and ideled for a few it smelled like it was burning. so I ran it back to the truck turned it off and it smelled like it was burning again. Is it overheating? is it running lean? I need help please...How do I fix it?
Old Jun 8, 2003 | 09:45 PM
Anyone out there!!!!!!
Old Jun 10, 2003 | 12:32 AM
anybody ever had this problem before?????HELP
Old Jun 10, 2003 | 12:54 AM
EAnmrider's Avatar
a little off subject but how fast does your bad *** 300ex get up to.
Old Jun 10, 2003 | 06:38 AM
dusty's Avatar
Just a shot in the dark, but did the dealer change the oil. Might just be some oil burning off the crankcase.
Old Jun 10, 2003 | 08:46 AM
garyc660R's Avatar
When you worked on the quad, some debris may have got on the pipe....if thats the case, it will go away.
Old Jun 10, 2003 | 10:19 PM
I pulled the plug out today and it eas white as a ghost. I guess that means its running lean. Did this hurt anything in the motor? It still runs fine.
Old Jun 11, 2003 | 08:13 AM
garyc660R's Avatar
Sounds like you need too at least go up 2 sizes on your main before running the machine any more.
bigred20653
Oct 2, 2015 10:05 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
bvolks
Sep 13, 2015 12:57 PM
Elkaholic
Sep 6, 2015 02:44 PM
