Torque Wrench
Old May 8, 2000 | 05:36 PM
eighthmercury's Avatar
Do you guys think it would be a good idea to get one. I was looking at all the bolts with specs, and there area lot. For example, do you all torque your plug? I saw in the manual that 1/4 to 1/2 trns past and tight is a good estimate, but t said that this is only temporary
Old May 8, 2000 | 06:06 PM
01ds650's Avatar
YES it is a good idea. Take care of them & they last a long time. I have both inch lbs & foot lbs.
Old May 9, 2000 | 06:10 PM
hot_shoe_cv's Avatar
You're right those specs are there fo a reason. The wheel lug nuts are some of the most commonly replaced/removed & they call for a rather low torque as I learned from experience..I let a friend help (?) me change tires once. He was only 14 but he twisted one stud off the hub. I couldn't get mad at him cuz he didn't know that Warriors only call fo 32 f/p, & neither did I at the time.
Sears makes an excellent digital torquer in 1/2" drive with both ft lbs & metric. Comes with a hard plastic case & full instructions.
Old May 11, 2000 | 12:09 AM
Blaster668's Avatar
Another good tool to have if you ever tear motors down is a Motion-Pro torque wrench adapter which allows you to torque the base nuts properly.
Old May 11, 2000 | 03:59 PM
-I need it to be 1/2 inch. That digital torque wrench sounds cool, but I am currently low on cash. So, If I get something, it should have a lifetime warranty(i doubt the digital components are)
-Also, My friend's ride has larger diameter studs on the wheel hub (I think they're called hubs) Is there a way to mount wheels that have smaller holes onto this hub?
Thanks for the help, I'm currently building up my workshop, but can only afford the necessities.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
exmotocrosser
Sep 26, 2015 08:18 AM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
